1 - 3 of 3 Posts
05' Sequoia 4WD
To start off yes I did search, but didn't find anything about the sequoia having this issue. (Could be stupid and missed something, if so sorry.)
I just picked up a 2005 Sequoia a couple of weeks ago and am taking care of some of the normal things that need to be done. When I bought it the glass and latch was not working properly so I ordered in a new OEM actuator and latch along with an all metal handle. I was able to get the glass working, and the whole latch assembly replaced with no issue and everything works perfectly with the exception of the lock.
I can lock and unlock the hatch with the lock/unlock button on the drivers door with no problem, however when I try to use the key fob I get a long beep and it will not lock. I immediately thought of a sensor issue but couldn't find anything. Is there is a sensor in the control module mounted on the door plate covering the inside of the lift gate? Has anyone else had this issue?
Thanks in advance for the help.
05' Sequoia 4WD
Discussion Starter · #3 ·
Yep, I dropped it off at my mechanic to have the timing belt done. I asked him to take a look at it but if he can’t make any progress with it I will try to find a wiring diagram of it and do some testing.
1 - 3 of 3 Posts
