1 - 5 of 5 Posts
i was wondering if anybody else has a problem with the dash board liftgate switch that only works intermitantly.Took it to the dealear & of course it worked
When you push the switch, do you hear 2 beeps ??
If so, then your doors are locked. The switch on the dash will not open the tailgate if the doors are locked.
At the time when the dash switch won't work, how else did you open the liftgate (i.e. did you walk back to the lift gate to open; or used the key fob to open; or just keep pressing the liftgate dash switch a few times until it eventually opens the liftgate)?
By the way, that dash switch seemed to me has a little bit of a delay has to "press-n-hold" a second, unlike the gas filler door a standard toggle switch.
Just as Rickvmax says "By the way, that dash switch seemed to me has a little bit of a delay has to "press-n-hold" a second, unlike the gas filler door a standard toggle switch"
Same here !
1 - 5 of 5 Posts
