1 - 8 of 8 Posts
I have a 6" fabtech lift and currently using 5.5" blocks to raise the rear end. I don't have much experience with tacomas, but have never liked the idea of using blocks with my other lifts.
What are the other alternatives for my 4wd, 4dr, 2003 taco? leafs, shackles, etc?
Thanks!
trd04taco
2004 Tacoma 4WD TRD
Don't use that big of blocks! That big of blocks puts a lot of stress on your springs and U-bolts. Instead, for economy, go with a 2.5" rear Add-A-Leaf (AAL) and a 3" block or 3" longer rear shackle. For an even better option, try Deaver or Alcan rear custom springs.
I thought that the Fabtech kit came with 3" blocks and 2.5" ProComp AAL's?
http://www.alcanspring.com/index.htm
http://www.deaverspring.com/customsprings.htm
Thanks!
that lift comes with a 3inch block and a 2inch add leaf.. so i have NO IDEA why you would have 5.5 blocks? are you sure that is what they are? measure them to make sure. But you can always get custom packs from deaver or alcan or some 5inch leafs from all pro. Or get the block out of there... do a 2inch block, 1.5 add leaf and 1.5 shackles. or a combo of your choice with those three or two of them.
Thanks!
oh i just noticed you are from utah> where are you located. We should meet up and go hit some trails and I can look your truck over and help you out with this rear end set up
Discussion Starter · #6 ·
i appreciate all the input. and sure enough- it looks like the off-roading outfit screwed me over with some big 'ol blocks. (my leaf springs are completely flattened out)
Does anyone know what the best set-up would be for offroading? Will I get anymore articulation with an oversized shackle/spring set up- or am I fine just going with some 6" springs?
Thanks again.
trd04taco
2004 Tacoma 4WD TRD
For good performance offroad, your best option is with new rear leaf packs. There are readily-available 5.5" springs from All-Pro Offroad that are designed just for our trucks. They aren't that expensive either. Right now they have a deal going where you can get new Bilstein 5100 shocks, bushings, extended brake line, and new 5.5" springs for $425. You can get just the springs for $249 right now.
http://www.allprooffroad.com/index.php?option=content&task=view&id=96
For a decent budget setup for offroading, you can get alcan rear AAL's and longer shackles for a good price from Toytec.
http://www.toyteclifts.com/9504tacocart.html#tacorearliftopts
Thanks again.
to bad you live in utah valley.. I am too north to be much help. I do not work for a off road company. I just have a good knowledge of tacoma's and this lift. Read this link it should answer all your questions.. good luck http://www.tacomaterritory.com/forum/showthread.php?t=58754
1 - 8 of 8 Posts
