1 - 8 of 8 Posts
· Stupid is stupid does
2008 tundra
light weight? How much HP would swaping out pulleys for lighter weight ones make? I thought under drive pulleys is what we want.
I had under drive pulleys on my mustang and I thought it was a total waste of time and money. My voltage was too low most times to even charge the battery properly.
· Hi-Miler
07 siver 4x2 Taco lo
you can get em.....even get them made
at best you might gain 2 - 5 hp maybe
for the cost.........you decide
you also mentioned flywheel
youd never see a benefit from a lightened flywheel unless you were
wide open ....& often
almost none regular driving
if an auto....it would probably drive worse
· what rock? oops...
underdrive pulleys are smaller diameter than stock so they dont spin as fast and the most common flaw is an alternator that doesnt charge the battery properly, but lightened pulleys are stock diameter just lightened usually made from aluminum which reduces the rotational mass.
I helped my friend put a "power pulley" (a lightened pulley) on his 67 baja bug and he went from 62whp to 67whp which is a huge improvement.
· Hi-Miler
guy you aint NEVER goping to get a 10%
gain in power just changing pulleys
maybe on his bug
but NOT a taco v6
that would b3 20-25 hp
thats a scream
1 - 8 of 8 Posts
