1 - 20 of 23 Posts
Hi Everyone
We are new to this section, as well as the toyotanation.com web forum.
My name is Caesar Rowinski and I am with LIGHTWERKZ. We specialize in automotive lighting, as you may have already guessed from our company name. We offer all types of headlight services and products including HID projector conversions, angel eye upgrades, headlight housing painting, HID systems, lens restoration, repairs, installations and anything else you can probably think of. If you have any questions for me regarding any products or services you may have seen on the site, or any technical questions, feel free to send me a PM or email, I will be more than happy to help you out.
I'm going to keep this thread going to show off some of the work we have done for this model, and leave it open for discussion should anyone have any questions.
[email protected]
Web- http://lightwerkz.net
Discussion Starter · #5 ·
And some output photos of the TFX system (what you can expect with the H1 bixenon projectors expect the H1's have more foreground lighting)
output from the TFX projectors:
Discussion Starter · #6 ·
LightWerkz is able to restore your headlight lenses with our top of the line equipment, techniques, and polishing products!
$80 - Stage 1- Removes hazes, swirls, lights scuffs and restores with high degree of luster. (Includes a 4 stage polishing procedure with rotary buffer)
$200-$300 Stage 2 - Full wet sanding procedure before polishing to completely remove all scratches, pits, and imperfections found in the lens. (Includes a 4 stage polishing procedure with rotary buffer)
Audi (Stage 2)
Imprea (stage 1)
Honda (Stage 2)
Discussion Starter · #7 ·
While we used to emphasize using only OEM components on our projects, we have personally tested these and the results have led us to believe that these are the highest quality HID kit found on the market today. The material quality and build quality of DIGITAL HID's products is second to none. Couple this with their lifetime warranty and it is clear why their kits offer the best value on the market. Our "55watt" kits feature 55 watt high-output DIGITAL ballasts and true 50w/55w DIGITAL HID bulbs. At 55 watts of true power, these ballasts will offer more light (30 - 40%) than any other HID kit on the market and have been proven safe with years of use with Stanley, Bosch, Valeo, and Hella projector optics.
Ballasts are 100% digitally controlled, extremely high efficiency, waterproof, require under 6.5A of starting current, and very low operating current for flawless plug and play operation! Bulbs are rated at 3500 hrs., with the least variance available on the market, all within +/- 100 lm and +/- 200K CCT.
All items are brand new and come with 2 DIGITAL waterproof ballasts, 2 HID Bulbs, mounting brackets, adapters, and a LIFETIME WARRANTY all in an attractive metal case!
CE and UL safety listed, ISO registered manufacturing, E4 mark.
Custom sizes and temperatures are available, please contact us TODAY!
Installation:
Our kits are designed to fit original stock headlamp sockets without modification, making installation a simple plug and play process. Often times installation can be done individually in a matter of minutes. But a professional installer is always recommended for performance and safety reasons.
LightWerkz wiring harnesses are recommended for a safer and performance maximizing installation.
Confused as to which kit your automobile requires?
Please visit Sylvania's Automotive Bulb Replacement Guide.
*Pricing includes shipping via US Priority Mail.
*Bi-Xenon kits include a fully plug and play relayed wiring harness.
can we some pics of the finished backs of your conversions? a lot of these conversions look great from the from the front but not so much when looking at the back. kinda like your everyday mullet sighting.
second, can a customer schedule an appt. for a single day to come in, have mod done, and leave? saving both time and shipping down time?
Discussion Starter · #10 ·
Hey Jon
We can give you a great deal if your interested, just email me!
99% of the conversions we offer look stock from the back, the other 1% we have to get creative.
Im sorry but I dont have any photos of the highlander rears, but I can get some other ones if your interested. Nothing to hide :)
Some conversions, like the H1 bixenon would be doable in one business day, but typically we need to hold the car/lights overnight.
also, the only thing i do not understand, is there cutting to my headlamp or it is only a lamp disassembly, install projector and shroud (is this also a plug and play), and install reinstall lens? I was a bit confused based on your post.
I guess what I am wondering is if it is a h4 hid bulb/ballast kit with a projector and shroud that gets installed without cutting.
I can handle the wiring and ballast install but was always unsure of the projector installation.
If there is no cutting, i can handle this. if there is, i defer to the experts. I can cut but definitely prefer not to when it comes to something like this.
Discussion Starter · #12 ·
Only up until recently (2 months or so) there have been options, such as the aftermarket h1/d2s bixenon projectors that do not require much modification, and even sometimes can be near direct bolt in. However all OEM projectors require cutting, drilling custom fabrications, etc. This is what we specialize in. However some people are on a budget and do not care for the absolute system on the market, so they choose a route that is less expensive.
Either way we offer the services to guide you through your projector conversion.
so i read your post as they did away with the easy option that requires no cutting? or it just came about recently. BUT even when available, the "almost" bolt in kit was of lesser quality?
I think I found what you are talking about in terms of an easier but non-oem fit. is the is morimoto mini h1 kits? if so, it does seem like an easier install. i might even tackle that on my own. if this is what you are talking about ( i found a link to your sight about these), maybe you can shoot me a pm about the pros and cons or just post it here.
02
Jimmy,
Have complete confidence in Lightwerkz. I went with them because of all the fantastic things I heard about their customer service. It's easy to sell a product, many businesses do, it's harder to stand behind your product for the long haul, Lightwerkz does.
I have a hot combination in my mind with gattling gun shrouds with angel eyes hidden behind but they wouldn't work with my setup. Maybe Caesar can mock up a projector with this shroud setup and post a pic?
I'm very particular with the mods I make on my $65k Sequoia, no regrets with Lightwerkz :thumbsup:
Jon
p.s. Caesar, say hello to the guys for me, next time I come up I'll show you my newest mod, a baby seat :lol:
Discussion Starter · #16 ·
The H1/D2S Bixenon systems, even though so inexpensively priced, they offer a great bang for the buck compared to the OEM projectors. So I wouldnt say it has lesser quality. The performance is not as good as some OEM out there, but on the other hand does exceed many of the other OEM projectors.
Here is a link to a comparison with all the bixenon projectors, you can see how well these two projectors stack up against the rest.
http://www.hidplanet.com/forums/content.php?2-Bi-Xenon-Output-Comparison-TL-E55-Murano-FX-IS-e46-LR3
It certainly is something you can tackle on your own if you have the basics to get started.
When I get a highlander in, I will do a mock up for you Jon. No problem! Congrats on the baby!
02
Thanks, maybe the next retro (of any vehicle) that would accept the gattling gun shrouds you could mock it up? Maybe if I show my wife how cool it looks I can convince her to let me have hers retrofitted.
:thumbsup:
ceasar, we might have to set up a time and day where i can come up and get this done in one shot. I cannot be without my truck with two little ones running around. Too much to do and come up with them. Maybe we can set something up on one of my off days from school in the near future. I know we have NJ teacher convention nov 4/5 i believe but am not sure if my wife is working. if I cannot find time to come up then I will tackle this on my own. I do almost everything on my own as it stands, and have since i was much more in the car game a few years back.
Discussion Starter · #19 ·
If its the H1/D2s, sure we can entertain the idea of you coming up for 1 day or even leave it overnight with us. Should be doable if I put the whole team on the job.
1 - 20 of 23 Posts
