1 - 13 of 13 Posts
LIGHTWERKZ HID Projector Retrofits, Angel Eyes, Painting, HID Systems & More- Rav4
Hi Everyone
We are new to this section, as well as the toyotanation.com web forum.
My name is Caesar Rowinski and I am with LIGHTWERKZ. We specialize in automotive lighting, as you may have already guessed from our company name. We offer all types of headlight services and products including HID projector conversions, angel eye upgrades, headlight housing painting, HID systems, lens restoration, repairs, installations and anything else you can probably think of. If you have any questions for me regarding any products or services you may have seen on the site, or any technical questions, feel free to send me a PM or email, I will be more than happy to help you out.
I'm going to keep this thread going to show off some of the work we have done for this model, and leave it open for discussion should anyone have any questions.
[email protected]
Web- http://lightwerkz.net
Here are some output shots of what you can expect your lights to look like after we retrofit them with the S2000 projectors.
And some output photos of the TFX system (what you can expect with the H1 bixenon projectors expect the H1's have more foreground lighting)
output from the TFX projectors:
Discussion Starter #6
LightWerkz is able to restore your headlight lenses with our top of the line equipment, techniques, and polishing products!
$80 - Stage 1- Removes hazes, swirls, lights scuffs and restores with high degree of luster. (Includes a 4 stage polishing procedure with rotary buffer)
$200-$300 Stage 2 - Full wet sanding procedure before polishing to completely remove all scratches, pits, and imperfections found in the lens. (Includes a 4 stage polishing procedure with rotary buffer)
Audi (Stage 2)
Imprea (stage 1)
Honda (Stage 2)
Discussion Starter #7
While we used to emphasize using only OEM components on our projects, we have personally tested these and the results have led us to believe that these are the highest quality HID kit found on the market today. The material quality and build quality of DIGITAL HID's products is second to none. Couple this with their lifetime warranty and it is clear why their kits offer the best value on the market. Our "55watt" kits feature 55 watt high-output DIGITAL ballasts and true 50w/55w DIGITAL HID bulbs. At 55 watts of true power, these ballasts will offer more light (30 - 40%) than any other HID kit on the market and have been proven safe with years of use with Stanley, Bosch, Valeo, and Hella projector optics.
Ballasts are 100% digitally controlled, extremely high efficiency, waterproof, require under 6.5A of starting current, and very low operating current for flawless plug and play operation! Bulbs are rated at 3500 hrs., with the least variance available on the market, all within +/- 100 lm and +/- 200K CCT.
All items are brand new and come with 2 DIGITAL waterproof ballasts, 2 HID Bulbs, mounting brackets, adapters, and a LIFETIME WARRANTY all in an attractive metal case!
CE and UL safety listed, ISO registered manufacturing, E4 mark.
Custom sizes and temperatures are available, please contact us TODAY!
Installation:
Our kits are designed to fit original stock headlamp sockets without modification, making installation a simple plug and play process. Often times installation can be done individually in a matter of minutes. But a professional installer is always recommended for performance and safety reasons.
LightWerkz wiring harnesses are recommended for a safer and performance maximizing installation.
Confused as to which kit your automobile requires?
Please visit Sylvania's Automotive Bulb Replacement Guide.
*Pricing includes shipping via US Priority Mail.
*Bi-Xenon kits include a fully plug and play relayed wiring harness.
Discussion Starter #8
Here are some photos for the job we completed today.
OEM Honda S2000 projectors
Lights painted semi flat black
Amber Removal
Angel Eyes
Discussion Starter #12
We just released our new HID systems.
They are available in H1 and D2S 35w kits only for now. Color temps available will be 4300K, 5000K, and 6000K.
Made specifically to be used for our HID projector conversions, but can be used for anything!
These are the highest quality aftermarket ballasts available on the market today.
Features:
Black aluminum casing with engraved logo and tech specs, no more peeling stickers!
Hidden sliding mounting bracket integrated in ballast
Improved heat radiation design with heat fins built into design to ensure longevity
Wide range input voltage 9-32V. which means it can be used on cars and on 24V trucks.
Improved electromagnetic EMC Circuitry -solves majority of known startup and failure issues with various applications
1 - 13 of 13 Posts
