1 - 8 of 8 Posts
I am new here.
My question is about a Toyota Camry 1998 make, which has over 140 k miles on it. It has a constant problem of Check engine light that comes up intermittently with P1780 code for the last 10 years. I took it to the dealership and changed park neutral switch couple of times and some other troubleshooting but the check engine light keeps coming back with the same p1780.
I couldn't find a mechanic who can resolve the problem. Any suggestions for troubleshooting? I am able to clear SMOG check every year but this intermittent problem keeps coming back. Thanks in advance!
Almost 1/2 Million Miles!
92 Toyota Camry XLE
Yes! I have the same issue!
It is no wonder my dash instrument cluster illuminates the R (reverse) when in any gear when the lights are ON! I believe it denotes that something is very wrong at my back-up lights!
Do your backup lights work? Check the wires in the trunk, drivers side hinge area. Could be broken wires.
Thanks for the suggestion. Yes, the backup light works. On a cursory glance, I don't see any wires broken. How do I check if the wires are having problems? Sometimes when I pull wires, the check engine light with P1780 code clears off and then comes again. Most of the time check engine light and same code comes on when I switch to reverse gear to back up my car.
short-throw dipstick
+1 on patcal. I had a '97 4Runner in with the same issues, and a few other weird ones: turn signals would hyperblink when pressing the brake pedal. The owner tried to install a backup camera that came with his head unit, messed up the hatch wiring, and ended up with a short to ground. Check all wiring, P1780 is almost NEVER a bad NSS.
92 Toyota Camry XLE
Yes, it certainly is not a NSS problem but, it sure affects it depending on the Electrical Issue (Short or Floating Ground) from broken wires somewhere!
Discussion Starter #7
Thank you for the generous suggestions.
I tried opening up the hood to glance wires, where do I start?
I have a multimeter - to check continuity - any weblinks or youtube videos or will repair manual such as CHILTON help?
I tried calling a couple of local repair shops, most of them don't have electricians and asking for unlimited budget
92 Toyota Camry XLE
So Sorry, we all have our limitations and if you don't know how to troubleshoot using Electrical / Electronic tools then, try to get a friend that knows, in case your budget doesn't allow to take to a shop.
Best of luck!
1 - 8 of 8 Posts
