1 - 16 of 16 Posts
2020 Toyota Camry SE
Hi all, so for I love my 2020 Camry SE+. But what I hate about it is when I listen to my music stored on a USB stick. Right now I have all the bands in their own folders on the root of the USB stick. Within each band folder, I have all their albums and within each album folder I have the songs. This is how it is when I look at the USB stick in my windows 10 machine. But in my car is not so straight forward. In the car, how do I see all the band folders I created in the root of the USB stick so that I can go into that folder, select which album i want to hear and then listen to the songs? when I pop in the USB stick and search using "Artists" or "folders", I don't see exactly what I see on my windows 10 machine. when I search using artists, i see several artists/bands that I don't have folders for. for example, I have a folder called "Various Artists" and within that I have Dio's tribute album which is an album with different bands covering Dio songs. so when I search for "Artists", I see each of those bands listed. And if I have other tribute albums, I see all those individual artists/bands listed, etc. so if the root of my usb stick has 10 band folders, I will actually see alot more than that. If I search using "folders", I still don't see what I see on my windows 10 machine. I don't remember exactly what I see. i'm not in my car right now. I also have a folder in the root of the usb stick called "new" which contains my newest music. I put the "" in front of it so it comes up at the top of the list. but not so in my car. I don't even see that folder in my car. how do I make this easier? basically I just want to select which band I want to listen to (according to the folders I have in the root of the USB stick), which album i want to listen to and start playing it. thanks for any help
When you browse the files on your computer, you're looking at filenames. The car is probably using the ID3 tag info which is different (specifically Artist and Album Artist). Cleaning up the ID3 tags is a pain in the butt, but that would probably fix your issues.
USB is poorly implemented on these cars. I wanted it to be great, but it's terrible. Bluetooth works much better IMO.
2018 Camry XSE V6
I've always used windows media player to sort and add idtags to the songs i ripped off of cds. If you purchased the music online then the idtags should already be on each song. If you ripped it from the cd or downloaded online for free cough...then you'll have to use windows media player or itunes to automatically add idtags information on each song by using their music data base. Make sure the titles on the tags are correct since it uses the titles to find the right song information
If I remove all ID3 tags, will my car see everything as folders and files like my PC does? and will the car know what title is playing, etc? I just need the car to read the folder names and file names. they tell me everything I need to know.
2018 Camry XSE V6
I never tried that, i always had idtags on mine. Most likely the songs will be under a folder named Unknown on the cars radio. If you want to separate the songs via band name and album, you'll need the idtags.
2018 Camry XSE V6
Yes. I am pretty sure most vehicles do that and also computers. itunes and windows media player adds the id3tags and sorts them into folders by the band name and album based on the id3tags
It's worse than that. While the system will find albums, even if you use pristine ID3 tags, it ignores the track numbers and defaults to an alphabetical sort. On collection albums, is you use random selection, that's OK but if you have albums with Broadway shows, movie scores, classical pieces, etc, the only way to get a proper order is to place the track numbers before the song title in the ID3 tag. There is another problem as well. Let's say you have a Smooth Jazz album with songs by many different artists. If you ask Voice Recognition to play that album, it will give you a list of the artists, not the actual songs. The work around is to put the same generic artist name in the ID3 tag for each song i.e. Smooth Jazz Artist. That's the only way that I've found that VR will bring up the album's song list. It's a royal pain but this is the the lack of attention or concern that Toyota has had for those of us who use a flash drive as music device.
Bootyologist
2004 Toyota Camry LE
I have the same problem. Sometimes the entune system splits my mixes some how and rearranges all the files and places them in a different folder. This problem occurs every once in awhile.
I'd gotten tired of the way the tunes were labled. Used MP3tag (free) to fix the problem. First, the car reads the filename and uses that to display for song title, then uses the info from ID3 to fill in the artist, album, genre, etc. MP3tag allows you to rename the mp3 (or flac, even) so the system will display properly. Now, when I take my elderly neighbor (93) up to the big city, I just choose 40's and she's happily quiet.
I am not sure how modern Toyota Head Units work, but I buy the CD's. Rip them using Perfect Tunes which searches online databases to ensure accurate meta data in the files, which I can edit at the time of ripping the CD. Then I rip them to uncompressed flac files. I drop them on my Note 8 on the 512GB memory card.
Then I use Power Amp Media Player (Android) to do all the cataloging. Pair the phone with the head unit over blue tooth and all I have to do is track forward, track reverse and volume controls on the steering wheel. Never have to pick up the phone.
1 - 16 of 16 Posts
