this is no good for him since his key will not turn at all.....There appears to be a rod that connects to the door lock actuator that is disconnected.
Watch this youtube and find how to remedy this solution. Good luck and let us know how it goes.
Jillsrav4 said the car starts up fine with the key. Also if the rod for the lock actuator is loose it will prevent the door from opening but the other 2 doors should still lock or unlock manually with the key. Unless the driver side is the main control the loose rod prevents a switch in the actuator from turning on the actuator on the other doors.this is no good for him since his key will not turn at all.....
each door lock cylinder would work independently of the other ones.....also when the door lock rod is disconnected the lock will turn when the key is placed in it....however if the key is not cut the same as the lock cylinders then the key will not turn in either direction.....since the key works the ignition fine one of 2 things has happened....either the ignition cylinder has been replaced and the new key does not fit the door locks or the doors or door lock cylinders have been replaced.....an easy way to test this would be to see if the key will lock and unlock the glove box.....if the key works in the glove box then my guess is the door locks or doors have been replaced.....if it does not work in the glove box then i would guess the ignition has been replaced......Jillsrav4 said the car starts up fine with the key. Also if the rod for the lock actuator is loose it will prevent the door from opening but the other 2 doors should still lock or unlock manually with the key. Unless the driver side is the main control the loose rod prevents a switch in the actuator from turning on the actuator on the other doors.
