1 - 12 of 12 Posts
Ron Jeremy's twin brother
06 Tacoma-SOLD
So for all of you that have removed or replaced your u-bolts, did you use loctite (blue) when assembling the bolts? Just wondering if this is standard practice, or just a personal preference.
Since I reused my factory bolts, but barely cleared the end of the bolt with the nut when I retorqued, I was thinking it might be a good idea to apply some loctite for added safety.
02 DubCab 4x4
I'm gonna use it....it's already purchased and ready to go.
I just picked up that people are using it for their U's.....so I'm gonna be a follower and use it as well.. seams reasonable and is cheap to do... can't hurt.
Trevor
Yes I used it, and I use it on all types of fasteners on my truck. I used red on the bumper and sliders and blue on suspension. A product like loctite will help you achieve proper torque specs as friction from rust and heat build up is reduced and dissipated as it acts as a lubricant when wet. Friction can alter torque numbers as it creates resistance lending itself to false readings.
Toyotanation
Because of the lube it will require less torque to secure the bolt. I forget where I put the chart. I have some info for dry, moly lube or loctite. Torque specs, It all goes by the size and grade of the bolt! Also what type of lube is used.
I might have a copy at work? I 'll try to post it, but it wont be until a few days. Sorry!
Essentially the lube lessens the friction required to turn a nut but the pulling force that is being applied to the bolt is greater. Basically if DRY it requires 80 ft/lbs to make a certain bolt yield. (stretch and fail) With lube it might fail at 60 ft/lbs. Friction plays a big part of the torque value.
Banned
I used red on the u-bolts, a-arm rods and the top front shock mounts (the 3 smaller bolts) and the sliders. I used blue on the bumper cause I'll need to get it off someday for a winch, and I don't want to do any more damge than I have to getting those nuts off. After the winch I'll use the red.
I figured I'd probaly have to cut the u-bolts if I ever changed anything back there anyway.
Surfing TN via iPhone
05 Tacoma DC 4x4 TRD
Blue Loctite will allow you to remove the bolt later. Red is supposed to make a permanent bond, but it usually doesn't. I can almost always break it loose.
A little interesting fact: Loctite works the opposite of standard glue. Loctite is in liquid form when it's in contact with air, but it hardens when there is a lack of air. Once you tighten the bolt it squeezes out the air between the threads, which makes the Loctite harden. It's really a neat product if you think about it.
Banned
I've never done it, but everybody says just a little heat from a butane torch will break the red loose again.
I also have this stuff called Titan for bolts that is made by Locktite (blue light-duty thread locker). It is not very good at all.
'06 Prerunner TRD
I didn't loctite my U-bolts, but I did torque them down to spec... I don't think this will present any problems as I check them every couple weeks...
06 Tacoma-SOLD
Discussion Starter · #12 ·
That's the same I've heard. But I don't see any reason why the blue wouldn't be effective, and I want to reserve the right to remove the bolts again if/when I replace the leaf pack. But since I'd need new bolts then anyway, cutting would work just as well.....
Thanks all for your feedback. I need to re-torque everything this weekend, so I'll probably just loosen the nuts and add some liquid insurance.
1 - 12 of 12 Posts
