1 - 6 of 6 Posts
Hi,
I understood that the LTFT will go down gradually if you increase RPMs. This would be an indicator of a vacuum leak. I’ve been looking for vacuum leak on my car recently, the LTFT are at 32% at idle but when a give it 2000-3000 RPMs it will instantly go down to -3%. Any idea why?
Thanks
I smoke tested the intake, spayed brake cleaner and propane everywhere. Everything seems nice and tight.
05 camry 07 tacoma
Could be drawing air thru the brake cylinder vacuum hose( disconnect plug to test) same test for purge valve.
No other error codes?
1 - 6 of 6 Posts
