To keep it short and sweet:
Has anyone been able to fix their DRL (BS), without spending $500-ish?! Maybe cut and ground the wire that shows "external temp" in the dash? I don't care about DRL, and I don't care to know what the external temp is, in my car! I just want the mileage!
- Got the car. Oil and trans fluid were pitch black
- Had oil, trans fluid and filter changed
- Everything worked better
- Found out that the IDIOT owner, didn't get the Daytime Running Light Service Bulletin done (back in 2003-2006)
- So at some (RANDOM, cold degree) the headlights turn on, and kill the battery
- Solution? $500-ish to solve. Car isn't worth that
- Instead: I disconnect the negative battery cable, and ONLY have to in winter
- Notice that trans shift pattern, reverts back to "pitch black" pattern
- Consistently get 19-24 mpg. Which is weird, when I have gotten 30 mpg
- Suspect shift solenoid gone bad, ask trans shop
- 01/12/2021... Trans shop uses OBD plug. Only way to make the comp/trans "re-learn" the shift pattern, is to disconnect the battery for 5 minutes.
- W. T. F?!
