My 2009 Corolla S is having a headlight/fog light problem.
Following are the symptoms.
Low Beams Switched On plus Fog Lights Not Switched On:
Driver side low beam bulb on "dim orangish", something wrong
Passenger side low beam bulb works properly
Both fog lights on "dim orangish", something wrong
Low Beams Switched On plus Fog Lights Switched On:
Driver side low beam does not work
Driver side fog light does not work
Passenger side fog light bulb works properly
High Beams Switched On:
Driver side: high beam bulb works properly, low beam bulb on "dim orangish"
Passenger side: high beam bulb and low beam bulb both working properly
Any suggestions as to what the problem might be and/or steps to diagnose?
