Hi everyone,
I have recently purchased a old 1993 Toyota Camry executive with 164000 KM. I just got it serviced but the radiator cooolant was not changed. So last friday I changed my radiator coolant with a mechanic. After changing the coolant I find overheating problems resulting in leaking of radiator. After installing new radiator, new problem arises. Now I find that after running about 300-400 metres, low oil pressure light is on. I took the car to the garage where I changed the radiator, but the mechanic could not fix it yet. He changed the engine oil twice - firstly with 20-80 oil and afterwards 30-70. the dipstick shows that the oil level is full. But the problem is not solved. I have got new oil filter on just 3 weeks back. the mechanic checked the pressure level, it shows that when the engine starts for the first time, psi is about 45 but after 2-3 minutes it falls to zero. After reaching 0, it does not change. I am in a fix, and needs your experienced suggestion.
Pallab
Pallab
