1 - 14 of 14 Posts
2008 Toyota Camry Base / CE
As long as they are similar to these they will work.
'21 Corolla Apex SE - 6mt - 👽
With the steel winters you'll need a beveled end to snug into the bolt holes. Toyota also has the lugs that fit into the aluminum rim with a washer inbetween the lug and rim... these will not work with steel winters or your spare.
Reactions: dicksonjoe
Discussion Starter · #6 ·
Ohhh
thanks
I have the stock SE rims and tires
so i can use those???
Discussion Starter · #7 ·
can you show me the ones that i will need? the type? i want to order it now. Thanks!!
Ohhh
thanks
My se lug nuts do not fit my steel spare I had to get new ones .
These are the beveled ones
https://www.amazon.ca/dp/B00B2FCACS/ref=cm_sw_r_awdo_navT_g_G7ZK4VFCCAEY6SZPDQ0Z
These are the style that come with the se
Did not check sizes just a style reference FYI
To be clear are you using steelies for the winters?
@Vangm25 had a solid comparison in the link he posted as well
2018 Avalon XLE Premium V6
Reactions: lE5QE0
1 - 14 of 14 Posts
