So my temp gauge seems to be foolin with me. Its about 80's to upper 80's here in TN right now so a bit hot, but my temp gauge will read halfway (operating temp) after the cars been running for about 30 seconds. Get to the bottom of my driveway, make it to the stop sign at the end of the road, and its at operating temp. Yet not blowing hot air yet. It will proceed to blow hot air after just a few more minutes of driving tho, ofcourse. Now for a couple of months, I've had my cooling fan relay bypassed, so the cooling fan just runs all the time, seemed to be tempermental (hah) aobut when it would kick it, usually would at the LAST SECOND once its about 2 marks away from the red. But I must say, the car definitely does warm up, and definitely makes it to operating temp. I think it actually may run a bit too hot, as well, because it wishes to overheat at times (hence the fan bypass). Is there a part or sensor I need to replace?
EDIT: By the way, I can pull over when it first hits "operating temp" on the gauge, and the engine is just slightly warm. Not even hot yet - hence why my heat isnt working for the first ocupla minutes, its just plain cold and thats all there is to it. Yet if i drive it for 30 minutes and get home, and the gauge is still at halfway even though the engine is hot enough to burn you if you touched it. So a good few hundred degrees of variation when the gauge is telling me "operating temp" doesnt seem normal to me.
