1 - 7 of 7 Posts
Hello all,
My MAF sensor went on my '89 Turbo and I wasn't able to find another to repair it. I ended up buying a Lexus MAF, RC 550cc injectors, and an Apexi S-AFC II computer.
Got everything installed but the car is barely running. :headbang:
I set the S-AFC on channel 4, it's the only channel I can drive the car under. The car hesitates and is next to impossible to accelerate. :confused: What Apexi settings are ideal to get the car running properly?? Any help at all would be GREATLY appreciated!
Thanks, Jeff :canada:
Got Hardass?
Jeff,
I've got the S-AFC2 running just fine in my car. Are you sure that you've got it set to be a "Karman" type sensor? IIRC they come from the factory set to use a hotwire MAF style setup and it must be changed.
Discussion Starter · #3 ·
Well, as it turns out it had nothing to do with my S-AFC and everything to do with yet another bad MAF electronics module. :liar:
I've bought three modules now (off Ebay) and finally have a good one. :clap: It came off a '89 so I don't know how long it'll last. Any idea where I can find a back-up module?
So the car runs fine now but I'm not sure whether I have the S-AFC II set up to give me the best perfomance. :dunno: Any guidance would be most appreciated.
Thanks again, Jeff
1990 Celica GTS
Try junkyard for backup. Then I don't think I've seen enough Camry with 3S-GE with MAF. They got tons of 3S-FE with MAP. Try to see if you can use MAF from another Toyota, maybe easier to find then a Supra one.
Since you have the SAFC, it can remap any MAF/MAP input to stock output.
Got Hardass?
Doesn't work that way at all. It allows you to take the input signal, and adjust it. IF your input is coming from a MAP, it will output a MAP signal.
1 - 7 of 7 Posts
