Not much needs to be done at 17000 miles. Just change the air filter and rotate the tires. Inspect fluid levels, brakes, CV boots, belts, etc while you're under the car or hood.
You don't need a torque wrench to rotate the tires. IF all you have is the wrench in the trunk for the spare, that works just fine. Don't jump on the thing...just push on it with the full weight of your torso and maybe a bit more.
