Recently my Rav4 maintenance light started blinking 8 times after startup then goes out. It is 2000 miles shy of its next oil change. I have found nothing that addresses this issue. Any ideas of a cause or solution?
2000, light reset at that timeHow many miles since last change?
I always reset the light. It was out than came on as described in 2000 miles.When you change the oil, go thru the reset procedure. That’ll get the reminder back in sync with reality.
As noted above, the light is reset as per toyota instructions in owners manual at each oil change.Search for reset procedure
