1 - 4 of 4 Posts
The maintence light stays on even though the engine oil checks out ok. This happened once before and I was able to correct the problem only I forget what I did...something to do with the odometer buttons comes to mind. Anyone have an idea?
2005 Toyota 4Runner
The maintenance light comes on every ~5,000 miles, or every ~5,000 miles after it has been reset anyway. Example... if you changed the oil at 3,000 miles but did not reset the light, it will still come on at 5,000 miles. Here are the instructions on how to reset it:
1. Turn ignition switch to "ON" position
2. Set odometer/trip display to "ODO" mode
3. Turn ignition switch to "OFF" position
4. Depress and hold the Trip Meter "RESET" button while turning the ignition switch to the "ON" position
5. The service maintenance reminder light will:
i. Illuminate solidly for 3 seconds
ii. Blink for 2 seconds
iii. Illuminate solidly for 1 second
iv. Turn off
6. Release the Trip Meter "RESET" button
7. Turn the ignition switch to the "OFF" position
8. Turn the ignition to the "ON" position and confirm that the service maintenance reminder light goes out.
1 - 4 of 4 Posts
