1 - 7 of 7 Posts
Does anyone have any advice on how to remove the dash in a gen3? I did a search as well as looked in my Haynes manual. Also how do you take out the interior trim pieces that fit around the front and rear seat belts? Any help????
Gen5.5 Sportivo V6
04 Camry Sportivo V6
with the dash removal, there are 4 screws in the Gen3 to remove, 2 above where the gauges are, and another 2 hidden behind the radio trim :p:, then after removing these, it should be a matter of pulling it loose and unplugging the accessories attached to it....
with the trim pieces around the front/rear seatbeats....i think that they are just clipped on, and you can carefully pry them off....:eek:
id get another opinion, because ive never touched those myself....
good luck :)
Go to your toyota dealership, and ask for pictures on how to remove your dash. I asked for diagrams of how my car was put together, so i could install a tv and rear view camera, and they printed off the trunk the whole interior, and the instructions on how to remove the dash. Very helpful people, you should try it.
Omar
Know God. Work Hard.
4Runner
The sides around your seatbelts are easy to remove.
First remove the plastic party on the door sils (Pull them off). Then just grab one side and pull it off. No bolts required.
Ford Powered
1999 Ford Mustang
well, to remove the dash i didn't need to remove anything from the glovebox, that is, unless you plan to remove the enitre dash cover.
1 - 7 of 7 Posts
