In Gen 5 what bulbs are there to replace for an instrument cluster? I havent seen any info on that. I saw gen 6 that has LEDS on the board but I dont know if a 2003 would be similar. The instrument cluster is WAY to dim for my taste.
I think SWACK/SACK is just how VLEDs calls their LEDs for Toyota vehicles. The color changing turn signals you talk about is called Switchback (autolumination also calls it this). VLEDs is the only site that calls their LEDs SWACK/SACK because its for special applications. Other than the load resistor or LED flasher module, nothing is needed for Switchbacks.The Swack bulbs are the LEDs that change colors right? For example when you change your turn signal, it will alternate between white and amber (also known as switchback). I know it is necessary to have an LED flasher but I was wondering if you need anything for the switchback to take effect. Is it just plug and and play?
The area with the yellow reflector has nothing to do with the parking/turn signals. That area has its own bulb (194/2825). It doesnt flash or anything.Very cool. I guess its only worth it if you strip the yellow housing and the sidemarkers.
Re: Sidemarker...go outside, turn on headlights and you'll see that it lights up. Activate turn signal or hazard and it doesnt blink.Very cool! Thanks for that info. Do you think you could take a picture of the sidemarker? I must be blind because I never noticed it.
Also when you get the time, do you think you can post a DIY on how to change the turn signals? I don't think its accessible from the engine bay.
Keep posting. You are really helpful to the forums. :woot:
Would anybody think that 2500mcd is too bright to replace the original leds?- Steering Wheel - QTY:3 (no Bluetooth) or QTY:5 (with BT) - 2500mcd 1206 smd (Gen 6); 2500mcd PLCC-2 LEDs (Gen 5.5) - buy from LEDMOD or eBay. *Soldering required
- Stereo Headunit (Gen 6) - QTY:8 - 2500mcd PLCC-2 LEDs - buy from LEDMOD or eBay. *Soldering required
- HVAC Controls (Gen 6) - QTY:6 (2 per knob) - 2500mcd PLCC-2 LEDs - buy from LEDMODS or eBay. *Soldering required
Depends on your preference. People will have different tastes. you can have a lower mcd if you want. so as long its the correct size. I dont know what the original led is.Would anybody think that 2500mcd is too bright to replace the original leds?
I am going to replace my originals, but i dont want it to be too bright.
Yes, to me it would be to bright. The LED's I purchased for my steering wheel controls are 35 mcd. They are still way brighter than the originals that were in its place.Would anybody think that 2500mcd is too bright to replace the original leds?
I am going to experiment with 180mcd and 2000mcd....Yes, to me it would be to bright. The LED's I purchased for my steering wheel controls are 35 mcd. They are still way brighter than the originals that were in its place.
The parking light/turn signal lens is clear. It looks yellow because the bulb is yellow. Had a chance to take pics since it was raining all week and when I was taking pics, it was drizzling...
DRL on with Parking Lights
DRL on with Parking Lights and Turn Signal
Black Housed TSX Retrofitted Headlights on with Parking Lights
Black Housed TSX Retrofitted Headlights on with Parking Lights and Turn Signal
Video coming soon.
My parking/turn signals are switchbacks. This was mentioned in this thread and on the first page. Like the 5th post or something. Its white and changes to amber because that is how the bulbs are. If you dont want to white, dont purchase switchbacks, just get normal amber leds. The front bulbs are 3157Awesome Job! One question, would it be possible to not have the white parking lights in the front? What type of bulb is there that it allows it to be a white light for parking, but blinks amber for turning while the parking lights are on? Again, awesome job! Are those the stock housings, but retrofitted and painted black?
Also stated in this thread, to change parking light bulbs, you have to access it through the wheel well.how did you change the parking lights?did you go through the wheel area or remove the headlights?i wanted to change the parkers but couldnt access it.thanks
Deja vu. I thought all the info needed was in the first post? I'll check and make sure. OH wait...it is!wasn't all this mentioned like 50 times already?
