Resistor DIY.
NOTE: i am not responsible for any damage that may be caused by this DIY. Use your brain and follow directions. We are messing with wiring..
First things first. Make sure to get these resistors:
http://www.v-leds.com/BlinkerWarning-Fix/Turn-Signal-Fix/3-OHM-50W-4-BULB-LED-p5679822.html
you can use them with eather 2 led bulbs or 4. there is no need anymore for 4 resistors if you have 4 led bulbs. just get the above 2.
the resistors specifically need to say they are for 4 bulb led!!
also i recommend getting these mounting plates to make mounting easier(and they are used in this DIY):
http://www.v-leds.com/BlinkerWarning-Fix/Turn-Signal-Fix/2-LOAD-RESISTOR-MOUNTING-p6841376.html
Now onto the instructions:
What i recommend to do first is to find the right screws and nuts for the installation. Uncover the cover over the 2 side pieces of the tail lights where all the bulbs are hidden. You will notice behind the cables there are studs that stick out with threads on them. these studs will he holding your mounting plates for the resistors. If you place the mounts there you notice the studs fit inside the top holes of the mounting brackets. try different nuts(carefully because they will fall in and it will be hard to get them out) until you find the right one to go over the long studs in the pictures below. it's better to do this now because once you tap the original wires the taps will be getting in the way when trying out the nuts.
this is the stud on the passenger side:
this is the stud on the drivers side:
Now that you have all the nuts and bolts that you need it's time to install the resistors. it doesn't really matter which side you start with. First thing to do is insert each wire into a separate tap and then secure the cable inside the tap by snapping the smaller half of the cover in (this will hold the wire inside the tap).
The following is for the drivers side.
Place the resistor alongside the bulbs similar to like in this picture (though this is installed but you get the idea):
For both positive and negative you take the wire from the resistor and put in as deep as possible in the empty hole. the wire will not go through the other side but instead just place it in as dead as possible.
The side that has the 50W text (exposed side - closest to you/trunk opening) will be put into the tap that is on the black/white wire (ground).
The side that is closest to the 3 Ω J (furthest in and covered by carpet lining) will be put inside the tap that is on the yellow/white wire (positive).
Now for the passenger side.
Place the resistor alongside the bulbs like before so that its like in this picture:
The side that has the 50W text (it is cut off in this pic..hidden by carpet lining) will go into the tap that is on the black/white wire (ground)
The side that is closest to the 3 Ω J (exposed side - closest to you/trunk opening) will be put inside the tap that is on the green/white wire (positive).
This is important so that you get the right side of the resistor going to the positive and negative. I did not try the other way around to see if it worked. i just tried it this way based on the diagrams on v-leds and it worked so i left it.
(added by dcemureviews: do not try other way. it will hyperflash. Follow Pawel062's way)
I suggest at this point installing some led bulbs to test everything went well.
Now that the resistors are installed and you have tested everything, you can screw them onto the mounting plates and put the mounting plates on the studs. if you done everything correctly then the wires should be hanging nicely on the bottom of the mounts and you'll notice that the mounts will fit nicely into those spots without touching any wires or getting to close to anything.
the passenger side might be pretty close to the bulb as shown in the picture below but the top of the resistor only gets hot so there is nothing to worry about:
i find it odd though how the passenger side seems to be different than the drivers side in wire colors and the placement of the studs.
last thing to do is just tidy up whatever is messy. I also have more pictures including the leds im using in action, extra pictures of wiring and resistors, and also my hids together with the leds.
i will be adding more pics and maybe more info once i do the resistor mod for my friend or my dad's camry. reason for this is i did this DIY after having the resistors in my car for about 2 weeks. i don't have pics from beginning to end and there could be a detail i forgot. If you have any suggestions, anything to add, or some better pictures please PM me and i'll edit this post. Once again ENJOY!!
Added by dcemureviews:
Troubleshooting:
- if LEDs are still hyper flashing, make sure:
1. you have the wire on "50w" side connected to ground (black/white) wire and wire on "3 Ω J" side is connected to positive (green/white or yellow/white) wire.
2. all wires are spliced correctly.
- I need to remove taps, how to remove? Take a very small or mini flat head and pry from the middle. Make sure it has a thin flathead. A normal sized flathead will not get under the cover.
