1 - 2 of 2 Posts
1991 Camry
i replaced this part 7 years ago with a brand new Toyota replacement..it was expensive!!...now its doing the same as the original part in that not controlling the drivers window[everything else works great].....anyone disassemble the switch and clean the contacts???
Gen 2 camry Guru
91 Camry Base
You can attempt to clean the switch and check the connection points for the switch. Depending on the style of the switch it could be a bad switch or a bad contact within the switch.
If this doesn't work you can get a replacement on ebay for 1/10th the price of what the Toyota dealer will charge you!!!
1 - 2 of 2 Posts
