First off, I'd worry more about fixing those exhaust leaks. There's really no point in adjusting anything on a car that's running improperly.
With stock intercooler and ecu you should be safe up to 15-16 psi. I wouldn't go past that, though, especially if you're already running that lean. Fix the leaks and get a good engine management system. Then tune it at a dyno and boost away.
Good luck!
Good luck!
