1 - 3 of 3 Posts
I need to replace my two back catalytic converters. Are they the same as the front ones? Is there a place I can get them reasonable?
Thanks I'm advance.
06 Tacoma Sport
I'm guessing you didn't even crawl under your truck and look at them yet? They are all different. If I got them from Toyota for my 06 Double Cab Long Bed TRD Sport, below is what I would get plus the associated gaskets and all new nuts/bolts. These parts are all bolt-ons, no cutting or clamping pieces together. They may or may not fit your truck. I don't know what you have or if there are differences between the trims and/or years.
(1) CAT built into the left exhaust manifold on driver side. Part # 17150-0P070 is about $500.
(1) CAT built into the right exhaust manifold on passenger side. Part # 17140-0P070 is about $500.
(1) CAT downstream in the exhaust on driver side with Y pipe. Part # 17450-0P030 is about $750.
(1) CAT downstream in the exhaust on passenger side. Part # 17410-0P020 is about $850.
1 - 3 of 3 Posts
