First post, though I've been a long time lurker. Most information I've found from searching in the past. I drive Subaru's, but the rest of my family drives Toyota's which I help with some of their maintenance and major problems. I'm trying to fix my sister's 2007 Rav4 (V6).
Vehicle shows CEL, VSC, & 4WD lights are on. I pulled the codes (9 total) which were
P0300 - random - multiple misfire detected
P0011 - Intake (A) Camshaft Position Timing - Over-Advanced (Bank 1)
P0015 - Exhaust (B) Camshaft Position Timing - Over-Retarded (Bank 1)
P0017 - Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor 3
P0301 - Cylinder 1 Misfire Detected
P0303 - Cylinder 3 Misfire Detected
and a couple repeats.
The vehicle seems to drive ok (no power loss), though I'm not used to driving this car. The idle is defiantly rough and the acceleration seems a bit jumpy, though this just may be the fact I'm used to 4 cylinder engines. I do drive a 4Runner fairly often and acceleration doesn't seem anywhere near as touchy.
During a hunt for an exhaust leak I located at the muffler, I also notice a diesel/tractor type sound coming from the engine itself. I'm assuming it's misfiring.
She bought it used at 55kmiles. It's at 75kmiles now. She drives very short distances to commute on the train to the city and drives back home to WV long distance once every few months. She only puts about 5kmiles on it per year with 2 oil changes per year.
Among the obvious is faulty sensors, I've read possible bad OCVs, and came across this http://www.toyotanation.com/forum/152-venza-forum/324381-tsb-2gfr-fe-engine-ticking-noise.html which seems unlikely since I don't hear a ticking noise (unless you count the diesel sound).
Anyone have any ideas to narrow down what it possibly could be before I start dropping money into parts?
