1991 mr2 n/a 173k and counting....
Hey, here is the scope... i got off work and started my car, warm it up and took off. Drives like normal. After coming out of a turn and gasing, i felt something strage an abnormal:
So i was in second gear and gasing up. hit ~2500 rpm and all of a sudden it sorta boost itself, it jerked, it stutters and the whole time my foot was on the gas padel, but i didnt foward it. same thing happens with all the gear. after a while pulled over and pop engine hood and white smoke from the back of engine came gushing out.
turned off car and cooled down for a bit.
Getting late and want to go home so i started the car again. car starts with out a problem. drive home slowly not passing 2800 rpm and obaying speed limit. when i came to a complete stop, car feels like it was about to shut off, engine shaking up and down.
Got home, parked car, engine still running. Called brother to come out and take a look. Loud unusal boomlike noise coming from exhaust every 1-2 seconds. Brother said miss firing?
Next day took the bus to work and left keys for brother to work on car. Changed spark plugs and seems to fix the problem. car runs smooth but seems to be lacking power. :thumbdown: Could it be the cheap spark plugs he replaced? would the platnium make a big differene? When he took out the spark plugs, he said that the 2nd one was all burnt, and leaking a whole lotta oil. :disappoin: Carpooling with sister. anyone know what went wrong and would new platnium spark plugs help bring back some power? He aslo said it might be the fuel cut? any takers on this?
thanks in advance and sorry for the long lenght
