1 - 3 of 3 Posts
I put a 5 sp manual from an 89 into my 87 to replace the automatic. Mechanically everything is fine. However, the ABS no longer works. I assume that's because the ABS is using a sensor from the auto trans which has a different wiring harness at the tranny. The 89 also has ABS. Does anyone happen to know how to get the ABS to work with this swap?
1 - 3 of 3 Posts
