I got what Fitment industries recommended for me as far as compatible tires with the wheelsThat tire size is too small. The proper size is a 225/40R18 which has a 25.0" diameter. The size you bought has a diameter of 23.9" which is way too small.
Well their information is very wrong. Good to do your own homework and not rely on others. That's what we as a group are here for, to help each other.I got what Fitment industries recommended for me as far as compatible tires with the wheels View attachment 291783
I'm not sure of the brand of fog lights. I bought them on eBay a couple of years ago and the are built in LED fog lights, not ones that use a LED bulb. There are a lot of different ones on eBay.SuperchargedMR2, what brand are the fog lights you have on your iM? Are those the Winjet ones? Since I'm going to have my car in to have the hood and front end repainted anyways, figured I'd do those at the same time.
Also, did some digging both here on the forums and and a few other sources that I trust, and I think I am going to end up going with the 17x8 Motegi MR131, with 235/45ZR17 Michelin Pilot Sport A/S 3 Plus tires. I've gotten from several people that those tires are way more grippy than the Neo Gen one, and have nearly as good a treadlife. And with the better tires, the pair are only about $70 more than the 18's would have been.
Do you have a Corolla sedan or Corolla iM? What year Corolla if it's a sedan? The front changed during production so that could change the information. Did you look on eBay for your year Corolla?Anybody still looking at this forum in 2020?
I have been looking all over the place trying to find a good set of day running lights to install on my base 11th gen. I'm trying to find either a pair of small stripes with LED on them, or find a good setup to add fog lights with a custom style with DRL that may work on the fog light assembly spaces (since my base corolla is not equipped with fog lights). Can anyone toss some links to where you have found any good DRL?
Yeah, it changed a lot during this gen.Do you have a Corolla sedan or Corolla iM? What year Corolla if it's a sedan? The front changed during production so that could change the information. Did you look on eBay for your year Corolla?
Well there are a bunch of choices on eBay so take your pic. Here is just one of many choices. for 2014 2015 2016 TOYOTA COROLLA CE L LE Bumper Fog Lights Lamps+Bulbs+Harness | eBayYeah, it changed a lot during this gen.
I have a 2016 Base Corolla sedan, which does not come equipped with fog lights, it just has the plastic covers where the fog light assembly should be.
I have already ran some cable and have an on/off switch mounted on my dash for some cheap Walmart small strobe lights o found for 20 bucks, but they no longer work (did not expect much from those 20 dollars). So I do not exactly need an overpriced "kit".
I found these DRL light strips on this website: Toyota Corolla LED Daytime Running Light Kit 2014-2016
But I think it is ridiculously overpriced for just LED lights.
Yeah, I appreciate it, but I am not really looking for the stock fog light assembly, instead I am looking for a custom day running light, but if I happen to find a custom fog light assembly which provides a day running light accent with it it would work great, but if not, just some nice looking day running lights would be fine since I have most of the setup already installed.Well there are a bunch of choices on eBay so take your pic. Here is just one of many choices. for 2014 2015 2016 TOYOTA COROLLA CE L LE Bumper Fog Lights Lamps+Bulbs+Harness | eBay
UPDATE; I found these LED strips on amazon: Amazon.com: iJDMTOY 7-Inch Xenon White Universal Fit High Power COB Continuous Lighting LED Daytime Running Lights (DRL Lamps): AutomotiveWell there are a bunch of choices on eBay so take your pic. Here is just one of many choices. for 2014 2015 2016 TOYOTA COROLLA CE L LE Bumper Fog Lights Lamps+Bulbs+Harness | eBay
You can always get some LED lights from The Retrofit Source and modify the fog light housings to use them as a DRL. I just use my Morimoto LED fog lights that I bought from TRS for my DRL on my 2009 Corolla S Turbo 5MT. I added some LED fog lights to my 2017 Corolla iM 6MT and I use them as a DRL also.Yeah, I appreciate it, but I am not really looking for the stock fog light assembly, instead I am looking for a custom day running light, but if I happen to find a custom fog light assembly which provides a day running light accent with it it would work great, but if not, just some nice looking day running lights would be fine since I have most of the setup already installed.
Also, here is a picture of the cheap strobe lights I purchased already installed on my car.
Sorry for late response my Man, your rides look absolutely awesome! I love that color combo, silver with dark accents.You can always get some LED lights from The Retrofit Source and modify the fog light housings to use them as a DRL. I just use my Morimoto LED fog lights that I bought from TRS for my DRL on my 2009 Corolla S Turbo 5MT. I added some LED fog lights to my 2017 Corolla iM 6MT and I use them as a DRL also.
Just about anything is possible with lights. You can always check with The Retrofit Source about some ideas from them. They are an excellent resource.Sorry for late response my Man, your rides look absolutely awesome! I love that color combo, silver with dark accents.
Even though, I am looking for something a little bit more custom like this picture of a guy with his amazing Corolla. But I haven't found any similar products. I feel like this addition to my car would be great and sort of kill 2 birds with 1 stone. Adding fog lights and some great custom LED DRL.
You need a better rear sway bar than more front bar on a FWD. Beefing up the RSB will make the handling more neutral and have less understeer.Looks like hardrace - who sells a front sway bar is based out of Australia?
Is there any US based suppliers?
Came across this front sway bar kit but still have to do some research, not sure if OEM replacement or if performance replacement:
Proforged® - Front Sway Bar Kit
Front Sway Bar Kit by Proforged®. Quantity: Sold as a Kit. Reasonably priced to fit your budget, this product is made in accordance with the most stringent industry standards to meet or exceed your requirements. Proforged 140-10014www.carid.com
With image: Proforged Chassis Parts 140-10014
I have BC Coilovers on my 2009 Corolla S Turbo and love them.Tried searching for deals within this community. But returned with nil.
Anyone aware of any deals going on? Looking for suspension upgrade. I may bite the bullet with coilovers. Hoping to save some money on my next upgrade.
