1 - 10 of 10 Posts
Where's my boomstick?
If I have a 500watt RMS 1ch amp, and im driving 2, 4ohm speakers, how much wattage will each speaker recieve?
and how will this be wired?
It depends on how you wire it as to how much power it will get. Is it 2 ohm stable? If it is then hook 2 wires from the positive terminal of the amp and run one to each positive of the sub. Do the same with the negative. If it isn't 2 ohm stable then you'll have to run one wire to the positive of one sub and run a wire from the negative of that sub to the positive of the other sub. Run a wire from the negative of the second sub back to the negative terminal of the amp. This will run an 8 ohm load so your power will decrease so it will more than likely be around 250 to 350 depending on the amp. If you run the subs in the 2 ohm setup and your amp isn't 2 ohm capable you will fry the amp eventually. More than likely it will be very soon as it will run much hotter than it is supposed to.
Discussion Starter · #5 ·
Lets just say 500watt RMS @4 ohms - with 2 4ohm speakers, wired which ever way provides the most power.
this is all hypothetical, i dont have any specific products in mind, just working out what i might need in the future.
What i probably would try and go with is one that is 2ohm stable and 2 2-ohm speakers. and try and figure the size amp i need from that.
Discussion Starter · #7 ·
thats cool, but i still dont know what size amp ill need
2005 Tacoma X-Runner
Lets say for example two Image Dynamics IDQ10's. They say to run them with 250w rms. If you have two IDQ10D2v2's they are dual 2 ohm subs. You can run those to a final 2 ohm load to the amp by wiring the dvc's in series. The type of amp you will need will be one that does 500wRMS @ 2ohm's. And is 2 ohm stable.
Dude, just make sure that the final ohmage of your speaker configuration matches the ohmage at which ur amp puts out maximum power. eg u dont want to buy a monoblock amp stable down to 2ohms and put a 4 ohm load on it. U would only be getting half the amps potential power. Just be careful u dont put a 2ohm or lower load on an amp that is only stable down to 4 0hms. (eg most 2 channel amps when bridged only r stable down to 4 ohms)
1 - 10 of 10 Posts
