1994 Toyota Camry LE
I actually have a few questions
1. Just replaced my 12 years old struts with Monroe Quick Struts. It took me about 6 hours to replace all 4 corners, but I guess it's not bad since it was my first time
Took the car for a test drive, everything was ok, but -
b) there is a very loud clunking noise from the front passenger side strut when going over bumps,
a) sometimes when I release brake pedal (from dead stop) I started to hear some squeaky noise coming from rear (there was no noise before strut replacement)
2. a) What is the torque spec. for rear strut lower mounting nuts? Monroe recommends 188 ft.lbs., however my repair manual says 145 ft.lbs if you reuse the old nuts and bolts. Is it ok to torque the old nuts to 188 ft.lbs.?
b) Is it really important to torque these bolts (see pic. below) to recommended spec.?
3.
some offtopic info
Pittsburgh brand from Harbor Freight
^good thing - this set came with lifetime warranty
3.
