Recently purchased some bushings-installed LCAs from Moog through a local store.
After some struggle, got the old ones off, and hefted the replacements into place...
And the rearward bushing was just wrong.
Not like "just torque it down harder" wrong, but really pretty bad. Here are some pictures:
The original:
Moog's replacement LCA with the bushing preinstalled:
A little more than a third of an inch difference. Obviously I figured somewhere in the process the wrong part had gone in the wrong box. Double checked the part numbers on the boxes, correct. Checked the alignment of the holes in the rearward, forward, and ball joint, all aligned. Called a different shop with some LCAs in stock, sure enough the Moog parts had this shorter bushing installed, other manufacturers (including basically brandless chinesium brands LCAs) had the taller bushings installed.
Posting here in case there is some other reason this isn't just a dumb mistake made by a manufacturer/assembler. Maybe this is the dimension for a preceding or succeeding model? Japan vs. America?
Either way it was a big hassle. Definitely not fun to start some critical part replacement on a DD and end up reinstalling old parts. I suppose I could have crawled down and taken a height measurement of the OG bushing as installed to compare before purchasing, but who does that?
The original:
