Thanks, I found that thread, and every other one that seemed relevant:
Wife told me that she has noticed that the sunroof has been open slightly a couple of times. I did a quick visual inspection and see nothing in the track. I put the vehicle back in the garage, turned it off and sure enough the sun roof pops open an inch or two when the vehicle is shut off. 2013...
www.toyotanation.com
Hello there! LTOFTP here! (Long Time Owner, First Time Poster) TL;DR: How do I manually close an '07 Avalon moon roof? I have a 2007 Toyota Avalon. It was hot outside when I bought a new battery, so I left the moon roof open when I made the change. From what The Internet™ tells me via Google...
Does anyone know why the what would cause the moon roof to stop opening/ tilting automatically. It works, but I just have to hold the button down to operate it. Makes it hard to make sure its closed up in the right spot, its a fine line between it dropping down to slide back, or tilting open...
Unfortunately none of the attempts at initializing the sliding roof worked, partly because the tilt up/down buttons do absolutely nothing in my case. Another post suggested the problem can be dirty switches, which is seeming likely:
the Up/Down switch on my 2012 Camry SE doesn't work half the time. Of course it works when opening it, but half the time won't work when closing it. I called today to order a new switch and the dealer told me they do not sell just the switch and I had to purchase the entire overhead console...
Before attempting a disassembly of parts not intended to be taken apart, I took a look at the diagnostics in the service manual:
www.tovenza.com
Most measurements check out fine (eg. the P4 sliding roof motor ECU harness voltages and resistances, and the P6 console switch open circuit resistances), except all of the ones relating to the switches being pressed (close/open, tilt up/down) which should be less than 1 ohm are all in the range of ~25 ohms. I'm not sure if there's something else to check, but those results don't seem good...
In case anyone is curious, removing the map light console is easy, but scary at first. It is held in place by two metal clips and two plastic clips all on the end of the console closest to the windshield, and a bit of velcro at the center, while the side away from the windshield is held by large fixed supports, so it should not be pulled there.
Toyota Venza: 2011 Venza passenger map light, how do you remove… It took some nerve, but pulling in a controlled manner from the windshield side suddenly popped out all 4 clips in one go. After that, the connector harness is easy to remove after pressing in a tab.
Now I'm not sure if I will brave a disassembly because it is clearly not intended. To get at the electronics and switches, 12 melted plastic "rivets" would need to be freed (orange ovals). Re-securing them might be tricky if melting the plastic, or messy if using glue or epoxy.
Luckily the measurements can be made first at the pins corresponding to the service manual (green square), or also at the five long metal contacts (red square). Of those in the red square, the right-most contact in the image is ground, and the other four correspond to the four possible switch positions (close/open, tilt up/down).
That's as far as I've gotten. Maybe I can brave it and try disassembling and cleaning the switches, or try to find a replacement console, or just live with the way it is. Any other options?
