1 - 20 of 24 Posts
i was talking to one of my buddies the other day about getting some more power from my rolla when he suggested i swap in new fuel injectors (he drives a civic and tends to rip parts out of whatever honda he can get his hands on, and tries to build pure frankenstien style shit lol). Anyways, he said there was noticable gains when he installed prelude injectors on his civic, and i was wondering if it was possible to do the same with the 4A-GE, and if so, any suggestions for a good donor car?
Resident asshole
Corolla
Injectors by themselves dont give you more power, just make your engine run alot richer = is bad. You want more power... add a turbocharger :D
nice guy
go with headers and intake....then get new cams. but be sure to time it after you put in your cams.
Discussion Starter · #5 ·
new clutch went in today cuz mine was shot lol
for headers i've only heard of 2 companies:pacesetter and kbd, any opinions on that?
not too sure who to go for to get the intake...
and as for the cams, unfortunately i'm pretty limited with knowledge about cars so... looks like i'm going to my mechanic for that one haha
I do NOT exist ...
i second the motion to think twice before trying Pacesetter for anything. they are really god-awful ...
i'd suggest buying a book by Pat Braden, i think it's entitled How to Build Your Toyota or something ... not sure on the title, but i know the author is Pat Braden. get it. i have it at home and it does discuss some things you can do to modify the OEM fuel injection systems and also swap parts between models.
my advice would be to do a complete exhaust (with a header) first though.
i have the KBD.... they're built well..... except the chrome can't withstand the heat.... and if you don't use spring exhaust bolts on the ball & socket joint, then you will blow the header - to - downpipe gasket like i always do... i've gone through 4
still chuggin' along
1981 Corolla SR5
whoa man, didn't know Pacesetter had a bad rep around here, they worked perfect for my bro's 4AGE, and my other bro's 22R-E. But those were some time back, have they changed for the worst:confused:
nice guy
oh thats perfect. put nitrous on a drifter.....your the smart guy:thumbdown :disappoin
noddygts said:
would it make any difference with the heat problem if they were ceramic coated or not?
any other companies that make 4age headers out there?
noddygts.... try www.tedcomponents.com. this guy Richard makes a lot of custom stuff at reasonable prices and he's located somewhere in Pickering/Ajax area. he's doing custom intake and headers and also a lot of engine internals. i've personally dealt with him before, he knows his stuff, he's been building 4AG race spec motors for a while now.
Guitars and Cars
2001 Corolla S
The guy was just making a suggestion and noddygts never said he was planning to drift the thing. Just because it's an AE doen't mean it automatically is a drifter:rolleyes: The AE92 is FWD:thumbup:
Always Bored
1994 Celica GTS
Check out the site www.club4ag.com they have a wicked forum for just those motors.
As for performance parts check out www.todaracing.com they make alot of 4ag parts.
My suggestion would be to find your self and older "blue top" 4age motor. Then I would use the blue top head on your car.
I would also use the existing injectors and fuel rail because of the flow and fitting. This would give you bigger intake ports and slightly bigger cams.
If you want more info on the "blue top" "red top" stuff check out www.club4ag.com or just pm me.
bluetop and redtop don't mean much...... redtops were actually from around 88-91.... however, in 90-91 the entire head and block were redesigned, and the loss of t-vis..... best way to refer to the generations is bigport and smallport (bigport being until 89... smallport 90-91)
hachi.... the 89 has a bigport.... so, what your thinking would be for him to find a 90-91 smallport and swap blocks (i'm assuming you're thinking of a bigport head on a high comp smallport block)
Discussion Starter · #19 ·
Well, turns out this guy i know said he could turbocharge my car for fairly cheap as long as i give him the car for a few months. He's fairly experienced with turboing hondas, but unsure with toyotas. I'm curious about general pricing so i don't end up getting screwed. Also, wondering how much boost i can run with stock internals. Thanks, any other advise will be greatly appreciated
for a quick and dirty setup... i was planning for around $500 on my mr2 to turbo it..... use a pressure switch to run the cold start injector for extra fuel.... use a 14b turbo (easily obtainable for $100), there was a kit on ebay for a manifold for $120.... and then run the afm in front of the turbo.... have exhaust shop buddies do a quick/dirty exhaust... and piping for an i/c to the trunk....
i was later planning on running a MS ecu setup
1 - 20 of 24 Posts
