no, they are not the same.
there is only one motor mount on the FWD/MR2 A series setups.... the 4af/4afe and the 4age do not share mounts... both the end that bolts to the motor and the end that bolts to the chasis are different as you can't mix/match parts.... however, you can use either on either motor as long as you have both halves....
meaning, both have 2 halves of the motor mount, but neither half is the same between the motors... but either will work on either engine. It's really annoying that they did it this way.....
MR2 mounts are also different, but closer to the 4afe mounts....
the C series mounts should be the same... E series mounts (non US) are not the same.... the only C series mount that is completely different is the lower mount in the middle.... and it's different on the 7a's versus the 4a's... even though they share bellhousings on the transmissions you can't swap them (oddly enough).
