I want to move/roll a vehicle with the front drive shafts removed. The vehicle is a 91 Camry all-trac This is the warning I read in the manual.
Is there an suitable home made replacement for the SST one could use to prevent damage?NOTICE: The hub bearing could be damaged if it is
subjected to the vehicle weight, such as when moving
the vehicle with the drive shaft removed. Therefore, if
it is absolutely necessary to place the vehicle weight
on the hub bearing, first support it with SST..
SST09608–16041 (09608–02020,09608–02040)
