They're raised by little electric motors. Do the following:
1. Test ALL fuses and fusible-links. Don't just look at them, pull them out and test resistance between the legs with voltmeter. If all fuses and fusible-links OK...
2. Get wiring diagram
3. Figure out wiring & colors to headlight motors.
4. Disconnect wiring-connector from headlight-motors and probe with voltmeter.
5. Turn ON headlight switch, do you have power to headlight-motor connector?
If YES, then motors may be seized or burned out. Replace motors if you don't want to repair them.
If NO, you don't have power @ headlight-motor connector, this may be issue with motor-relays or light switch upstream. Go up wiring harness and test upstream components.
