1 - 7 of 7 Posts
camrys blow off too!
06 subaru wrx wagon
do you have anything done that would require an upgraded ignition?
Turbo on the way. but also ive noted the car runs alital ritch. and my spark is not to healthy for the fuel geting dumped into it.
the short and narow is id like to get more spark in there, to take advantage of what i got now, and what i will have when i get the turbo on it.
06 subaru wrx wagon
yeah, if you are gonna turbo it in the future...wouldnt be too bad of an investment
MSD Components
Ok, try the 6-series ignition, plus a coil, since you have the external coil. I have the 6AL in mine, and it made a noticeable difference (I have alot more done, and I just hooked it up, so your results will vary). They have lots of additional "add-ons" for the 6-series ignitions, and they are cheaper than trying to install a "race use" ignition. Get the 6AL now, and when you go turbo, you can get their seperate BTM Vaccuum Advance add-on (I have one I am using as a paper-weight right now awaiting money for the turbo upgrade), plus you can get their Programmable Timing Master.
http://msdignition.com/tc_20.htm
http://msdignition.com/tc_11.htm
http://msdignition.com/ignition_6.htm
http://msdignition.com/coil_blaster_3.htm
1 - 7 of 7 Posts
