Part Two (limited to 10 photos per post)
Sound System:
For starters, I've installed a lot of sound insulation using the following:
The stock sound system is the Entune Premium Audio with Navigation. I chose to keep the head unit, but it is very rarely used.I keep it on the "home" screen with Navigation and Weather showing (if anyone knows how to disable the display, please let me know). 95% or the time I keep the head unit's display off. I use the it pretty-much only for navigation and speaker-phone. When I do use the head unit for sound, it's either for IPod or CD (AM, FM, HD FM and satellite all have really crappy sound quality to my ears so I don't use them). For music my primary source is a FiiO M11 Plus LTD DAP (power and automatic on/off is provided by the aforementioned USB port).
I have the M11 set to "in-vehicle" mode so it will automatically turn on and resume to what I was last listening to when the car is turned on. Stored on it is about 800GB of music files. Nearly all files are lossless with most being 16bit/44.1kHz. A growing number of 24bit/192kHz files are being added as I acquire more. I also use it to stream MQA audio through Tidal.
The M11 is equal to or above CD quality that feeds a digital coax SPDIF signal to an Audison C20.
(This converts the SPIDF signal to fiber optic as the primary source.)
The sources (FiiO DAP and Toyota head unit) are fed into an Audison AP F8.9 bit DSP/Amp.
The DSP/Amp is set up as two channels feeding 85W each into two tweeters (Audison Voce AV 1.1) in the dash, two channels feeding 85W each into two mid-woofers (Audison Voce AV 6.5) in the front doors and four channels (bridged to two channels) feeding 300W each into two sub-woofers (Audison Prima APS 10 S4S) in the spare tire well.
Source switching as well as volume, sub-woofer level, balance and crossover points are done with a Digital Remote Control (Audison DRC MP). The front seat heater controls have been relocated to inside the center console
All-in-all I am very pleased with the results. My car is my audio oasis/escape so I feel justified with my outlay of time and $$$$. I plan on keeping this car until it dies. Hopefully it won't meet an early death like my last Avalon.
Sound System:
- CLD (Constrained-layer Damping); Kno Knoise Kolossus. I've installed about 140 sq ft throughout the car.
- CCF (closed-cell foam); Vibro 6mm. I used about 20 sq ft.
- Butyl Rope; Second Skin. I used about 10 ft.
- Tesa tape. I used about a roll.
