My Baby!!
1079 Views 10 Replies 5 Participants Last post by  Jayota
Greetings all, so I have a 94 xtra cab 4x4 truck, I have put a new engine in it and just recently another 2 grand in it replacing head gaskets, breaks, ect. Anyway, I can't get it to shift into gear until it warms up and am wondering if it needs tranny fluid. The problem is I don't know where it would go or do I need to take it to the shop....AGAIN. If by chance it needs a new tranny, does anyone know the cost of that. Thanks for any and all inquiries. Cheers! Oh, did I mention I love this truck more than my children, just kidding, I love them all equally.
1 - 11 of 11 Posts
Do you have a 5sp or auto
Check the trans fluid level by removing the 24mm plug located on the drivers side of the transmission. Fluid should be level with that plug.
r150 trans rarely go bad. A used one would cost you a few hundred.
Remove the shifter and inspect the shifter seat and bushing. IF they are bad replace with the marlin pieces.
Reactions: 1
could have to wrong gear lube in it..to thick lube will do that
Reactions: 1
Ok so I have no idea what this plug looks like I looked all over, but can't find anything that resembles or says tranny fluid here
So I went out to check the truck and it won't shift att all now, and the clutch is super loose. What would that one mean...HELP!!
Check the clutch master cylinder's fluid level. You could have a leak somehwere between there and the slave cylinder.
That plug wehre you check the fluid level is going to be ON the tranny, not in the engine compartment like and auto.
okay when was the clutch done on the truck?
Have to checked the fluid in the master?
The 24mm plug/bolt will be on the drivers side of the transmission. Crawl under the truck and look around
What have you checked period?
1 - 11 of 11 Posts
