1 - 5 of 5 Posts
The brakes are starting to make noises and smell like burning. I think I may have gone too long before changing the pads. Is it likely I'll need to also replace the rotors? How can I check for sure? I searched the archives for recommendations on pads and rotors, seems like Brembo rotors and PBR Ultimate ceramics might be a good setup, though on the more expensive side. It's the wife's car so it doesn't have to perform like a race car. Is the setup I've described more geared towards performance than day to day boring commuting?
I appreciate your comments.
Bark
Grenaded piston
You might need to replace the rotors depending on the condition.
If theres any cracks, warping, or deep grooves you need to replace them.
If there still in good condition, you can have them turned.
To check the rotors for warping & thickness you use a micrometer. There should be a number stamped into the backside of the rotor, that number is the minimum thickness.
Sometimes there is a little bit of a shimmy when braking, is there any other way to tell if they are warped? I mean, can the naked eye tell or does it require a machine to measure warping?
Where can I get a micrometer?
Thank you!
Grenaded piston
You need a micrometer or a special jig to hold the rotor and a dial indicator to measure the runout (amount of warping).
Sears should have them.
This is what it looks like:
1 - 5 of 5 Posts
