Hey long time no post ^^
Yesterday my heart skipped a beat, for the first time ever the engine check light came on while I was on the way home from uni. The Vienta has been such a reliable car since I've had it, the only issues have been age related and easily fixed apart from the headgasket.
In any case I got it home and used the paperclip trick to read the engine codes and I was given these:
21 – Main Oxygen sensor signal fault
24 – Intake air temperature signal fault
31 – Air flow meter circuit or vaccum sensor signal failure
41 - Throttle position circuit fault
55 – Knock Sensor fault
I was told that I needed to clear the codes, warm the car up again and the get the codes again and these will be the ones I need to fix. I reset the EFI, went for a drive to warm the engine up again and then went to read the codes and they were all gone.. I'm happy for that but now I'm worried that the problem is still there and that all I've done is just clear the codes. Can anyone shed some light on this?
Aside from this the car has been going great. When I've finished my studies I'm planning on dropping the stroked engine in and then working on a rear mount turbo. I really didn't want to have to get another set of headers made for the car since the whole exhaust is custom anyway so I figured this would keep it simple while keeping the heat out of the engine bay and not cramping it up more than it already is!
