... is in.
It's an all day job.
Spent half a day on the rear maneuvering the old bar out and new bar in. The other half a day on front is breaking loose and torquing down four big bolts.
Deployed impact and cheater bar. :lol:
Front is 4.5kg/10lbs vs. stock 4kg/9lbs
Rear is 5lbs vs. stock 4lbs
Stock sway bars measure at dia. 23/14mm F/R.
Once the rear bar is in place it is much easier to install than front. In the front the brackets have no indication on which goes which side and how. I can only go by illustrations in instructions and intuition. Then ...
One of the bolt holes on one of the bracket has stripped threads. WTF? :wtf: :facepalm: I wrote Hotchkis and I'll see if I can get a replacement. And can someone fab a 29mm bushing for the stock bracket? Just in case I have to use the stock bracket?
