ok ive done a lot of research on the subject, but i want to hear it from you guys with experience. On a 3vz-fe I plan to get a zex wet kit (or any wet kit) 100 shot. Ive heard from other people that they run 100 shot on their camrys (1mz even- more fragile???) no problem. I also heard that you can advance your timing to about 15 degrees on a stock camry and it nets you to about 15hp.
My question is what octane fuel should I run, what timing should i be set at, should I upgrade fuel pump?
