1 - 2 of 2 Posts
This shift linkage part is cracked and the lever attached to the end of the shift cable is completely loose where it enters the transmission. What part name(s) should I be searching and does the problem run deeper into the transmission than it appears requiring specialist attention?
Second-hand relayed additional info: Car does not shift into 1-3 but 4-5 continued to function.
"Dust Boot" or "dust boot for shift and select lever shaft"
part number 33531-12020
retail price 14.45
13 left in the country
If the Lever is loose, you might have more issues inside that need to be addressed. There are springs locks and clips and all sorts of goodies attached to that shaft.
1 - 2 of 2 Posts
