1 - 4 of 4 Posts
Does anyone know if a Nav ready head unit from a 2019 Limited or XLE can be installed in a 2019 LE Model? Need to know if the wiring harnesses are compatible/the same
If you're willing to do a little removal remove the trim and what not and the few bolts to pull out your radio.... And then take some photos of your harness to compare to the photos already on this forum. There's a good chance there's little difference in the harness itself if i had to guess.
Also since people have swapped android head units into it regardless if they have an LE or a limited and higher trim it likely is the same.
Usually they design these things with cost savings in mind.
ya that's probably the way to go.
didn't think of it. Doesn't seem too difficult to get the radio out looking at the u tube videos!
Thanks SEleonard
1 - 4 of 4 Posts
