1 - 9 of 9 Posts
Hi, i'm looking at a 91 MR2 N/A on ebay and the bid end in like 6 hours so i need help quick. The guy says his A/C pump is frozen so the A/C doesn't work. Now i called a toyota dealership and they said its not an A/C pump but a compresser, and you will need a few other parts like R12 cooling stuff. He said all together is would be like 1200 bucks to get the A/C working. Is this true, or does anyone know a way to get the A/C working? Thanks
it depends on what is wrong with the AC system...could just be out of refrigerant to the compressor being dead....unless u live in the southern US regions...u should be able to live w/o ac..i took mine out.....
Discussion Starter · #3 ·
i live in jersey, now if the the guy said that the AC pump is frozen. I dont know what that means or how much it would cost to fix. Now one more thing, if the AC doesn't work that doesn't mean the heat doesn't work either does it?
You should be able to find a used a/c compressor online @ mr2.com or maybe even ebay.A used unit will be much cheaper than a new one from toyota.Also dont use r12 freon.While you are in there convert it over to 134a.That will save alot.A can of r12 is like almost $80,where as a can of 134a is only $4.Labor will be another issue.Take it to a qualified tech that can be sure it is installed properly and not leaking freon anywhere else.
1 - 9 of 9 Posts
