1 - 1 of 1 Posts
I am finishing up changing the timing belt on my 97 Camry V6. I lost track of the crankshaft mark at TDC. What is the easist way to determine TDC of the compression stroke so I can line up all 3 timing marks. 2 on the cams and 1 on the crankshaft sprocket. Also if the mark on the crank sprocket is lined up could I be 180 degrees off?
1 - 1 of 1 Posts
