this is gonna be long so i can fully describe the problem.
like the title says. i have a 88 sc mr2 and 2 years ago it died while i was driving, it would restart and run for about 30 sec basically last through first gear, then it would die over and over again as i returned 10 miles back home, dieing just about every time first gear tops out. but sitting at home all it did was idle, oddly it ran fine for a few months the next season. then this last summer it started dieing again with the same symptoms and now it will die at idle. usually runs 10 minutes then stalls, it will restart every time and after the first time it dies it will only run for a few sec or so. i was checking a few things and have found out its a ignition problem. i put the timing light lead (you know it goes around wire #1 normally) around the coil wire and ran the car in the driveway, the coil stops producing spark (yup the light stopped flashing lol) causing the car to die. i was thinking it was the ignitor getting hot and shutting off or something. re-grounding the coil was recommended else where so i gave it a shot, didnt help. so ive been trying to buy a coil and igniror for a gze with no luck every time some one has one for sale i get skipped over and they sell it to someone else. so im wondering if anyone has had this problem, or can at least give me a idea how to diagnose it? is the sensor in the dizzy common to fail? how about the resistor lookin thing on the coil ground? or should i continue my never ending search for a ignitor?
please help i drove my mr2 8 miles last year
